delete vm-tracking local-vm
delete vm-tracking local-vm {mac-address mac}
Description
Deletes the specified VM entry in the local VM database.
Syntax Description
mac
Specifies the MAC address for a VM entry to delete.
Default
N/A.
Usage Guidelines
None.
The following command deletes the VM entry for MAC address 00:E0:2B:12:34:56 in the local VM database:
# delete vm-tracking local-vm mac-address 00:E0:2B:12:34:56
This command was first available in ExtremeXOS 12.5.
Platform Availability
